Введение
This guide will walk you through replacing it step-by-step if your Amazon Echo Show 10 (3rd Gen) camera is experiencing poor image qualty, malfunctioning during video calls, or even not working at all. Replacing the camera can restore proper video and face-tracking functionality to your Echo Show.
Before you begin:
This repair requires moderate disassembly of the device, so take your time and keep track of small screws and cables.
Выберете то, что вам нужно
Видеообзор
Insert a Jimmy along the seam of the screen and the shell and slide it along the length to separate the two sides.
Hold the display away from the board at an angle to ensure a clear view while keeping the ribbon cable slack.
Place the tip of your opening tool under the edge of the display connector, and pry the connector straight up from its socket.
Set aside the display.
Place the tip of your opening tool under the edge of the orange connector, and pry it straight up from its socket.
Use the T5 Torx screwdriver to remove the two 4 mm screws from the bracket covering the microphone board and the one 4 mm screw holding down the board itself.
Use a spudger to pry under the microphone board. and gently wear away at the connecting glue.
After the adhesive seal has been broken, gently lift and remove the microphone board.
Remove the silver pannel's eight T5 Torx screws:
Eight 7.8mm black screws
To reassemble your device, reverse the steps outlined in this guide.
