Введение
This guide will walk you through the replacement process for the Motherboard found within your Amazon Echo Show 10 3rd Gen device. Refer to tweeter replacement guide as a prerequisite in order to get to motherboard.
Выберете то, что вам нужно
With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
Remove the lid and set it aside.
Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
Place the shell aside.
Rotate the device to lay on its side with the tweeter's exterior facing you.
Unhook the 3-pin connector attaching the tweeter to the base with your fingers. Hold it as close to the base of the cord as possible, and lift it directly up from the socket.
Use a Phillips screwdriver to remove the four 10 mm screws attaching the tweeter to the main speaker base.
Remove the six 6.8 mm screws using a T6 Torx screwdriver.
Remove the metal bracket.
Еще один человек закончил это руководство.
1 Комментарий к руководству
hola modulo de wifi, esta integrado en la tarjeta madre?
