Введение
The motherboard contains connections to all major components of the device. If you need to replace your volume or power buttons, you will have to replace the whole motherboard. This same information goes for the headphone jack and the charging port.
Выберете то, что вам нужно
While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
Then, remove the back cover from the device.
Pry the speaker from the case using the iFixit Opening Tool.
Lift the speaker up from the device to remove the speaker wires from their groove in the case.
Desolder the speaker wires from the motherboard.
This step is completely unnecessary. The cords don't get in the way of the rest of the procedure. Feel free to disregard this step.
Use a PH0 size Phillips screwdriver head to unscrew the five 2 mm screws on the motherboard. These screws are circled with red in the given image.
The LCD- Motherboard connector cable has a protective overlay that you must peel back with precision tweezers in order to expose the actual connector.
Gently pull down on the connector cable using precision tweezers in order to disconnect the cable.
Pull black tab at connector upwards first, then flex cable can be pulled easily.
The LCD Digitizer on the Amazon Fire tablet has a locking cable connector that holds it in place on the motherboard.
To remove the cable, use the iFixit Opening Tool to unlock the LCD Digitizer cable connector.
Once the wire connector is removed, use the iFixit Opening Tool to pry the entire LCD Digitizer away from the motherboard.
The volume and power buttons must both be repositioned in order to remove the motherboard.
To reposition the power and volume buttons, use the iFixit Opening Tool to pull the plastic casing upwards. Then, remove the casing completely.
The rear facing camera wire connector must be disconnected in order to remove the motherboard.
To remove the rear facing wire connector, insert the iFixit Opening Tool beneath the connector and wedge it upwards.
Position the iFixit Opening Tool beneath the motherboard and pull upwards to remove the motherboard from its case.
Thanks for the information, very useful. Does anyone know how the power button works? wiring? I am thinking of replacing it with a small push button. Mine broke. Thanks in advance, Jorge
22 участников успешно повторили данное руководство.
5 Комментариев
where can i get a motherboard from for a 5th gen 2015 ??
Great manual!!!!!!!
Where is the hard drive? I need to replace that
It doesn't use a hard drive, it has a flash chip underneath the big shield on the board which can be pried off with a screwdriver but to remove the chip you will need a heat gun.
Donde puedo conseguir ese touch de esa table
