Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This mouse was designed with usability in mind taking little to no effort to fix anything.
Выберете то, что вам нужно
Use the screwdriver to remove the stickers hiding the screws marked in red.
Pry the center of the mouse apart to separate the upper and lower housing of the boards.
Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
Pull the Scroll wheel, in red, to the left to remove it.
Replace/clean if needed.
If your mouse still doesn't work after this step, please continue onto the next step.
Один комментарий
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
