Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show you how to disassemble your Anker mouse to repair the scroll wheel with little to no experience required.
Выберете то, что вам нужно
Use the Phillips #0 screwdriver to remove the stickers, marked in red, that hide the screws you will need to access.
Pry the center of the mouse apart to separate the upper and lower housing of the boards.
Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse.
Pull the scroll wheel, marked in red, to the left to remove it.
Replace/clean if needed.
If your mouse still does not work after this step, then continue to the next instruction.
Один комментарий
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
