Anker 2.4G Wireless Mouse Sensor Replacement
Выберете то, что вам нужно
  1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: шаг 1, изображение 1 из 1
    • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Sensor Replacement: шаг 2, изображение 1 из 1
    • Using your Phillips screwdriver, remove the four screws.
  3. Anker 2.4G Wireless Mouse Sensor Replacement: шаг 3, изображение 1 из 2 Anker 2.4G Wireless Mouse Sensor Replacement: шаг 3, изображение 2 из 2
    • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
    • Make sure you are not using too much pressure, as you could warp the plastic.
  4. Anker 2.4G Wireless Mouse Sensor Replacement: шаг 4, изображение 1 из 1
    • Disconnect the wires from the white crimping headers.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse Sensor Replacement: шаг 5, изображение 1 из 1
    • Remove the scroll wheel from the motherboard by pulling it to the left.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
  6. Anker 2.4G Wireless Mouse Sensor Replacement: шаг 6, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Anti-Static Wrist Strap
    $7.95
    Купить
    • Gently lift the motherboard away from the plastic housing.
    • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
  7. Anker 2.4G Wireless Mouse Sensor Replacement: шаг 7, изображение 1 из 1
    • Desolder the six wires holding the I.C. in place to complete the sensor change.
    • Replace the broken sensor with the new sensor and solder back in place.
    • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
Заключение
2 участников успешно повторили данное руководство.
Ryan
Участник с: 01/23/14
140 Репутация
1 руководство автора
Команда
Cal Poly, Team 1-39, Maness Winter 2014 Участник Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 17
За всё время: 7,504
