Anker Soundcore 3 Charging Port Replacement
Выберете то, что вам нужно
  1. Anker Soundcore 3 Charging Port Replacement, Battery: шаг 1, изображение 1 из 2 Anker Soundcore 3 Charging Port Replacement, Battery: шаг 1, изображение 2 из 2
    • Gently heat the perimeter of the device with a hairdryer to loosen the adhesive.
    • Insert a metal spudger in between the speaker's front grill and chassis.
    • Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
  2. Anker Soundcore 3 Charging Port Replacement: шаг 2, изображение 1 из 3 Anker Soundcore 3 Charging Port Replacement: шаг 2, изображение 2 из 3 Anker Soundcore 3 Charging Port Replacement: шаг 2, изображение 3 из 3
    • Remove 8 of the 10 mm screws from the speaker panel using a Phillips #0 screwdriver.
    • Using the metal spudger, gently pry at the outer-edges of the speaker to remove the rubber/plastic panel that sits above the motherboard.
    • Grip and disconnect the cable connector from both the rubber/plastic panel and the mainboard.
  3. Anker Soundcore 3 Charging Port Replacement: шаг 3, изображение 1 из 2 Anker Soundcore 3 Charging Port Replacement: шаг 3, изображение 2 из 2
    • Remove the four 10 mm screws that secure the battery with a Phillips #00 screwdriver.
    • Firmly grasp the connector cable and gently pull up to remove it from the mainboard.
    • Remove the battery.
  4. Anker Soundcore 3 Charging Port Replacement, Charging Port: шаг 4, изображение 1 из 2 Anker Soundcore 3 Charging Port Replacement, Charging Port: шаг 4, изображение 2 из 2
    • Remove the two 10 mm screws that secure the charging port with a Phillips #00 screwdriver.
    • Using a metal spudger, remove any glue that may be holding the charging cable in place.
    • Firmly grasp the cable and disconnect it from the charging port.
    • Remove the charging port.
Заключение
Lucas_Jerina
Участник с: 08/28/24
269 Репутация
Автор 2 руководств
Команду
University of North Texas, Team 5-3, Kilpatrick Fall 2024 Участник University of North Texas, Team 5-3, Kilpatrick Fall 2024
UNT-KILPATRICK-F24S5G3
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 85
