Введение
If you are experiencing issues with the LCD screen on top of the brush, this guide will walk you through on how to take apart the brush in order to replace the screen. Soldering is involved, so if you don't know how to solder take a look at How To Solder and Desolder Connections.
Выберете то, что вам нужно
Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
Remove the circuit board and heating element from the handle.
This will make it easier to work on for later steps.
Using the soldering tool, melt the solder holding the LCD screen on the circuit board.
The screen is soldered in 11 places on the circuit board. Melt each of these points and remove the screen.
Now that the LCD screen is removed, use a soldering tool and solder to install the new screen on the circuit board.
Solder at the same 11 points where you previously melted to remove the screen.
