Apple EarPods Jack Plug Replacement
Выберете то, что вам нужно
  1. Apple EarPods Jack Plug Replacement, Jack Plug: шаг 1, изображение 1 из 1
    • Cut the wire at a length comfortable for the headphone user (preferable close to the old jack plug).
    • Using a wire stripper, remove about 1-2 cm of insulation from the end of the wire.
    Necesito ayuda pero no son los mismos earpods los cables que tiene son de la siguiente manera: rojo, verde, 2 dorados (por separado) y uno azul envuelto con el dorado
    Le Rorro - Ответить
  2. Apple EarPods Jack Plug Replacement: шаг 2, изображение 1 из 1
    • Insert the wire through the plug cover.
  3. Apple EarPods Jack Plug Replacement: шаг 3, изображение 1 из 1
    • Seperate each wire from each other.
    • Make sure to have 6 different wires: Red, Green, Gold, Red-Green, Gold-Green, Red-Gold
    The golden one is with the red-green, you have to untangle it from there
    José Vitor Lobo - Ответить
  4. Apple EarPods Jack Plug Replacement: шаг 4, изображение 1 из 2 Apple EarPods Jack Plug Replacement: шаг 4, изображение 2 из 2
    • Burn off the insulating wax from the signal carrying wires with a lighter and/or use a knife to rub it off.
    • Use caution if burning off insulating wax with flame so as not to burn yourself.
  5. Apple EarPods Jack Plug Replacement: шаг 5, изображение 1 из 2 Apple EarPods Jack Plug Replacement: шаг 5, изображение 2 из 2
    • Solder the wires to poles on the jack as outlined in the steps below. Poles are shown in the first picture segmented by the color boxes. For proper soldering technique please use: iFixit Soldering Guide
    • The first pole (Marked with the red box) is grounded. Solder on the green-gold, red-gold, and red-green wires. The third picture refers to this step.
    • The second pole (Marked with the orange box) is for the right earbud. Solder on the red wire.
    • The third pole (Marked with the yellow box) is for the left earbud. Solder on the green wire.
    • Finally, the fourth pole (Marked with the green box) that is not connected to the rest is for the mic. Solder on the gold wire.
    This is wrong! The Mic is the red&green cable and the gold cable doesn't exist in my earpods. There is a 6th cord however which is a nylon like support cord.
    Andi - Ответить
  6. Apple EarPods Jack Plug Replacement: шаг 6, изображение 1 из 1
    • When the solder hardens, screw on the jack cover.
    I soldered all the wires correctly as mentioned, but my volume keys not working
    Nitesh Rathod - Ответить
Финишная черта
5 участников успешно повторили данное руководство.
Shashwat Patra
Участник с: 02/20/19
313 Репутация
1 руководство автора
Команда
University of Memphis, Team S2-G4, Baddour Spring 2019 Участник University of Memphis, Team S2-G4, Baddour Spring 2019
UM-BADDOUR-S19S2G4
2 членов
Автор 5 руководств
6 Комментариев
Difficult, indeed, but I made it, and it works! Great satisfaction! One modification in the process, I’ve made – instead of burning the isolation inside wires, I separate the wires, and cut out isolation, because it was unable to solder in different way.
Chris - Ответить
Step 5 wrong! The Mic is the red&green cable and the gold cable doesn't exist in my earpods. There is a 6th cord however which is a nylon like support cord.
Andi - Ответить
The gold wire is hidden inside the red-green wire. Unwind the red-green to find it. The gold is the mic, the red-green is the mic ground. If you use the original jack (cut away the moulded on white plastic) you can use a multimeter to find the mic connection which is on the other side of the ground connection. Thanks for the page. Good luck
Jonathan -
I recycled the same factory jack and identified the poles with a multimeter. I followed the same instructions. Their volume is lower than usual. Thanks for the page.
Gustavo Padilla Rivera - Ответить
This article was pretty useful for me. Great thanks to the author and also people who commented here.
Mehdi Misaghi - Ответить
I used this guide to do a "reverse" operation - cut away non-functioning airbuds and soldered the lightning DAC to RCA jacks, now I can connect my iPhone X to the amp. Thank you!
Raman Chakhouski - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 51
За последние 30 дней: 260
За всё время: 28,702
