Инструменты
Запчасти
Детали не указаны.
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Turn the laptop over and remove the three T8 torx screws from the bottom panel.
Turn the laptop back over and open the monitor.
With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
Lift up and forward on the front portion of the laptop. Watch out for the ribbon cable, and disconnect it by pulling the cable straight up and out of its connector.
Unscrew the two torx #8 screws holding the mouse button in place.
Then slide the button out.
Unscrew the last torx #8 screw holding the trackpad assembly in place.
Now the entire trackpad will lift out of place.
Disconnect all ribbon cables by pulling them up and out of their connectors.
