Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removing the logic board is a very simple procedure. Hopefully you never have to do this to your Apple TV. Just a note... There is nothing wrong with my Apple TV. I made this guide for those that may need to use it one day. My Apple TV is still running well
Выберете то, что вам нужно
Use a spudger to pry the bottom cover off the Apple TV.
It may be necessary to use two spudgers (one to hold it open while you pry with the other one)
Remove the pink thermal pad. (I already removed mine)
Remove the five philips #1 screws securing the heatsink and logic board to the upper casing.
Using a screwdriver (flathead) or a spudger, pull the power cable out of the logic board
Use a flathead screwdriver or spudger to tilit the logic board to an angle so you can grab it with your hands
Holding the logic board by it edges, lift it up slightly.
And remove
Thats all. The logic board has been removed. Just follow the steps (Step 1-5 in reverse to install the board)
The chip with the grease on is the Apple A4 chip. The thermal pad took the silkscreen off, so its hard to read.
The The black ball surrounded by meta is the IR Remote sensor.
In the third picture, the power connector and LED status connector are shown.
HDMI Port
Micro USB Port (used for diagnostics, and service)
Digital TOS Link out (Optical Out)
Gigabit Ethernet
7 участников успешно повторили данное руководство.
