Apple iPod Dock Connector Cable Replacement
Выберете то, что вам нужно
  1. Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: шаг 1, изображение 1 из 3 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: шаг 1, изображение 2 из 3 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: шаг 1, изображение 3 из 3
    • Unscrew the four Phillips screws on the backside of the docking system.
    • The screws are located quite deep. Make sure you have a long screwdriver to be able to reach the screws.
    • Be aware of the plastic threads. Using too much force can tear this up.
  2. Apple iPod Dock Connector Cable Replacement: шаг 2, изображение 1 из 1
    • Separate the housing in two parts.
    • The dock connector is slid in two parts on the top of the system, make sure you slide the two housing parts in this line of direction.
    • The two parts are glued on the sides of the speakers. Use some force to separate the two housing parts.
    • The internal parts are still connected to each other. Don't pull the housing parts too far from each other.
  3. Apple iPod Dock Connector Cable Replacement: шаг 3, изображение 1 из 1
    • Slide the dock connector out of the housing part.
  4. Apple iPod Dock Connector Cable Replacement: шаг 4, изображение 1 из 1
    • Unscrew the three screws using a Phillips #2 screwdriver to remove the T-shaped circuit board holder.
  5. Apple iPod Dock Connector Cable Replacement: шаг 5, изображение 1 из 1
    • Remove the T-shaped circuit board holder.
  6. Apple iPod Dock Connector Cable Replacement: шаг 6, изображение 1 из 1
    • Remove the circuit board from the housing part.
    • The circuit board is still connected to another circuit board with a cable.
  7. Apple iPod Dock Connector Cable Replacement: шаг 7, изображение 1 из 1
    • Disconnect the 5-pin connector between the two circuit boards.
    • The connectors are tightly connected. Hold the other circuit board to prevent it from breaking while disconnecting the 5-pin connector.
  8. Apple iPod Dock Connector Cable Replacement: шаг 8, изображение 1 из 2 Apple iPod Dock Connector Cable Replacement: шаг 8, изображение 2 из 2
    • Look how the cables are oriented.
    • Take a picture with your phone. It's easier to look it up than recalling your memory.
  9. Apple iPod Dock Connector Cable Replacement: шаг 9, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Desoldering Pump
    $3.99
    Купить
  10. Apple iPod Dock Connector Cable Replacement: шаг 10, изображение 1 из 1
    • Heat up the solder.
    • If you don't want to damage your workspace, it's probably handy to place something underneath.
    • The circuit board will be getting hot. To make it more stable you can clamp it in a vise or alligator clips.
    • The heated solder tends to fume—do not inhale this! Do this in a well ventilated room.
  11. Apple iPod Dock Connector Cable Replacement: шаг 11, изображение 1 из 2 Apple iPod Dock Connector Cable Replacement: шаг 11, изображение 2 из 2
    • If the solder becomes fluid, keep the desoldering pump near the solder.
    • Push the button on the desoldering pump to suck the solder.
    • Solder will solidify fast, so you need to act quickly.
  12. Apple iPod Dock Connector Cable Replacement: шаг 12, изображение 1 из 1
    • Strip the cables with a wire stripper.
  13. Apple iPod Dock Connector Cable Replacement: шаг 13, изображение 1 из 2 Apple iPod Dock Connector Cable Replacement: шаг 13, изображение 2 из 2
    • Check if the cable is in the right position.
    • Heat up the contact point on the circuitboard.
    • If the contact point is hot enough, you can add a little bit of solder.
    • Don't inhale the fumes.
Заключение
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde vanaf stap 7.
Anoniem
Участник с: 03/08/17
19 Репутация
1 руководство автора
Команда
Delft University of Technology, Team S1-G6, Flipsen Spring 2017 Участник Delft University of Technology, Team S1-G6, Flipsen Spring 2017
TUD-FLIPSEN-S17S1G6
3 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 22
За всё время: 478
