Archos 97 Carbon Display Screen Replacement
Выберете то, что вам нужно
  1. Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: шаг 1, изображение 1 из 2 Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: шаг 1, изображение 2 из 2
    • Lay your tablet upwards facing you.
    • Using the opening tool, begin by prying the tablet starting in the top left corner. This can be found near the volume and power buttons.
    • Begin to work your way around the tablet in a clockwise motion to separate the screen from the cover.
  2. Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: шаг 2, изображение 1 из 3 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: шаг 2, изображение 2 из 3 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: шаг 2, изображение 3 из 3
    • Once you have opened the screen, you will see two cables that connect the screen and the interior of the tablet.
    • Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab.
  3. Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: шаг 3, изображение 1 из 2 Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: шаг 3, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • On the left side of the tablet, you will see a silver cable connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape that is connecting the cable and screen. This will allow the gold connector to come loose.
    • The screen should be separated from the tablet.
  4. Archos 97 Carbon Display Screen Replacement, Removing the screws: шаг 4, изображение 1 из 2 Archos 97 Carbon Display Screen Replacement, Removing the screws: шаг 4, изображение 2 из 2
    • Remove the screws on the backside of the screen using a screwdriver.
    • There are four screws; one is covered by tape.
  5. Archos 97 Carbon Display Screen Replacement, Removing screen from frame: шаг 5, изображение 1 из 3 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: шаг 5, изображение 2 из 3 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: шаг 5, изображение 3 из 3
    • Gently pry the screen from the black frame that surrounds it using the opening tool.
    • Work in a clockwise motion until the screen is detached from the frame.
Заключение
2 человек успешно провели ремонт по этому руководству.
Allyson Seber
Участник с: 03/03/15
311 Репутация
Автор 2 руководств
Команда
Sam Houston State, Team 13-5, Blackburne Winter 2015 Участник Sam Houston State, Team 13-5, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G5
3 членов
Автор 8 руководств
1 Комментарий к руководству
Hi,
Is this similar to replacing the touch screen on the Archos 101B model?.
colin - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 47
За всё время: 1,994
