Введение
A stand created by three legs is a common method of supporting a load.
Выберете то, что вам нужно
Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
To disassemble your device, follow these instructions in reverse order.
Еще один человек закончил это руководство.
1 Комментарий к руководству
Can I order the following part that was missing from the order that came in Aug 2025?
Please let me know, I can pay for these parts from you stock or spare parts.
36 x 10mm Nut/Bolt Pairs
6 Pipe Ring Brackets
12 x 14mm Nut/Bolt Pairs
2 Cooker Assembly Adjustment Star Knobs
Paul
my email is pn91006@yahoo.com
626-215-4038
Paul Ng
