Astro A40 TR Internal wiring components Replacement
Выберете то, что вам нужно
  1. Astro A40 TR Internal wiring components Replacement, Speakers: шаг 1, изображение 1 из 2 Astro A40 TR Internal wiring components Replacement, Speakers: шаг 1, изображение 2 из 2
    • To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
  2. Astro A40 TR Internal wiring components Replacement: шаг 2, изображение 1 из 3 Astro A40 TR Internal wiring components Replacement: шаг 2, изображение 2 из 3 Astro A40 TR Internal wiring components Replacement: шаг 2, изображение 3 из 3
    • Remove the dust cover located on the speaker. Use the corner of the spudger to peel underneath the cover until you can lift it by hand. The cover is held onto the device with adhesive and should be removed slowly.
  3. Astro A40 TR Internal wiring components Replacement: шаг 3, изображение 1 из 2 Astro A40 TR Internal wiring components Replacement: шаг 3, изображение 2 из 2
    • Take off the front cover by removing the four screws located in a square formation on the surface of the device. Use the J00 Philips driver listed in the device page.
  4. Astro A40 TR Internal wiring components Replacement: шаг 4, изображение 1 из 2 Astro A40 TR Internal wiring components Replacement: шаг 4, изображение 2 из 2
    • Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
  5. Astro A40 TR Internal wiring components Replacement: шаг 5, изображение 1 из 1
    • If your issue is asking for the complete replacement of the speaker or the motherboard, un-solder the old components and replace with new speaker by re-soldering.
    • Check out this useful guide on how to solder and desolder connections if soldering is new to you.
  6. Astro A40 TR Internal wiring components Replacement, Internal wiring components: шаг 6, изображение 1 из 1
    • Untie the disconnected wiring harness.
  7. Astro A40 TR Internal wiring components Replacement: шаг 7, изображение 1 из 1
    • Pull the black wire out of the hole in the device.
Заключение
2 участников успешно повторили данное руководство.
Mike
Участник с: 10/20/16
448 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 6-5, Martin Fall 2016 Участник UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 57
За всё время: 7,482
