Введение
Speakers may get damaged or stop producing sound. This guide will help you replace your headset's speakers. The removal process is the same for both the left and right speakers.
Выберете то, что вам нужно
Remove the magnetic ear pads by gently pulling up away from the head set.
Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
6 человек успешно провели ремонт по этому руководству.
5Комментарии к руководству
Great, pictures and explaining. But where do i get an speaker to replace the old one?
I am also looking for the replacement speakers. They seem impossible to find
hola me encantaria que me pudieran decir donde comprar el repuesto de uno de los altavocez, porque no encuentro nada
Awesome, but I don’t believe see anywhere on how to fix the mic as it rotates 360 free spinning rather than locking in the 90° talk and mute positions…?
this is almost no solution, your cover is broken, there is stop on plastic cover.
