Введение
If the touchpad on your Asus Chromebook Flip laptop (model C302A) stopped working after you tried troubleshooting, you may need to replace it. You may need to replace it if it is damaged as a result of it not being disabled in the BIOS or if it has Corrupted Operating System files that probably caused the damage. If this is the case, this is the guide for you. This guide will walk you through the process of safely removing and replacing your touchpad.
A laptop's touchpad serves the same purpose as a desktop computer's mouse. A trackpad is another name for it. The touchpad controls the mouse pointer, also known as the cursor.
With that being said, make sure your laptop is turned off and unplugged from any outlets before you begin removing the components. It is best if you gather all of your tools in one place before beginning to replace this component. We recommend that you use the iFixit Magnetic Project Mat to keep your screws organized. Choose a location where there will be no children to interrupt you to prevent them from using tools that could harm them.
Выберете то, что вам нужно
Remove two rubber caps on the top.
Remove the two 1 mm screws using the Phillips #00 screwdriver.
Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
Carefully remove the back panel using an opening pick.
Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
Remove the two 2 mm screws from the speakers using a Phillips #00 screwdriver.
Инструмент, используемый на этом этапе:Tweezers$4.99
Detach the cable that is connected to the motherboard using a pair of blunt tweezers.
Flip up the ribbon cable tab using a pair of tweezers.
Disconnect the cable by holding the blue tab with your fingers and pulling out towards you.
Detach the ribbon cable and silver adhesive attached to the computer by pulling it up towards you.
Use a spudger to pry up all around the edges where the screws were to loosen the trackpad.
