Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Is your Asus Transformer Pad (TF103C) display not doing what it should be? Is the LCD screen black or not working correctly? This guide will walk you through the steps of replacing the LCD screen of the Asus Transformer Pad.
Replacing the screen is complicated, and has more than 25 steps to achieve. Removal of multiple small electronic parts and chips are required to get access to the LCD display.
Remember, punctured batteries can cause dangerous fires, so use caution when handling the battery.
Выберете то, что вам нужно
Make sure the power is off.
Insert the plastic opening tool into a crack on side of the tablet.
Carefully pull the tool upwards to and pry open the Transformer pad.
Slide the tool in the gap along all four sides, continually pulling the tool upwards.
Remove the back cover once it is loose and set it aside.
Rotate the tablet so it matches the picture.
Carefully unplug the battery cable from the motherboard by grabbing the wires close to the black piece and pulling it out of the housing.
Remove the yellow tape and unplug the wire that attaches both speakers to the soundboard.
Use the +J000 screwdriver to remove the screw. Then, remove the plastic cover that is labeled "M2".
Note: You will be breaking the seal sticker on the screw.
Remove the black tape from the ribbon cable and separate the cable from the soundboard.
Remove the black tape from the motherboard. Unplug the ribbon cable from the volume and power buttons.
Unhook the camera ribbon cable from the underside of the motherboard and remove the motherboard.
Use the plastic opening tool to pry the display screen from the front panel.
For better results, use opening picks and glide them around the screen tape. Note: you may need to replace the tape.
9 участников успешно повторили данное руководство.
2 Комментариев
I was wondering if you could tell me which ribbon cable connects the screen, and in particular the touch input to the main board. I would guess that it is the one labeled 14010-00190900.
I am having the problem with intermittent touch input failure, and since my device is not on warranty, I thought I might try replacing the ribbon cable.
