Asus X5511M-RCLN03 Battery Replacement
Выберете то, что вам нужно
  1. Asus X5511M-RCLN03 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Position the laptop with the back cover facing upward.
  2. Asus X5511M-RCLN03 Battery Replacement: шаг 2, изображение 1 из 1
    • Remove all 4 mm screws using a #00 Philip's screwdriver.
  3. Asus X5511M-RCLN03 Battery Replacement: шаг 3, изображение 1 из 1
    • Open the laptop with the keyboard facing upward.
  4. Asus X5511M-RCLN03 Battery Replacement: шаг 4, изображение 1 из 1
    • Carefully pry up the keyboard cover with your fingers or with a plastic spudger.
  5. Asus X5511M-RCLN03 Battery Replacement: шаг 5, изображение 1 из 2 Asus X5511M-RCLN03 Battery Replacement: шаг 5, изображение 2 из 2
    • Remove electrical ribbons by gently lifting up the tab that is holding them down, then pulling them gently.
  6. Asus X5511M-RCLN03 Battery Replacement: шаг 6, изображение 1 из 1
    • Set the keyboard plate aside. Gently lift up battery to remove it.
Заключение
3 человек успешно провели ремонт по этому руководству.
Ryann Easterbrook
Участник с: 01/12/17
154 Репутация
1 руководство автора
Команда
Oakland University, Team 2-5, Ruskiewicz Winter 2017 Участник Oakland University, Team 2-5, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G5
3 членов
Автор 2 руководств
3 Комментарии к руководству
Peer review:
Step 1: This step is unclear and seems unnecessary. It should be removed or reworded to be more specific: "Position the laptop with the back cover facing upward."
Step 3: This step is also unclear and seems unnecessary. It should be removed or reworded: "Re-position the laptop with the back cover facing downward."
Step 5: This step is grammatically confusing and should be reworded. Example: "Lift up the tab covering the electrical ribbons. Pull the ribbons gently to remove them."
Courtney Clark - Ответить
Steps 5 and 6 are missing photos so the instruction is not clear.
This was a easy and strait forward repair it took longer to find the tools than to do the repair. The hardest part for me was plugging the flex cables back in as I have a tremor in my hands. the repair took about 10 minutes.
DANIEL HATHAWAY - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 1,849
