Asus X553MA-BPD07051 Optical Drive Replacement
Выберете то, что вам нужно
  1. Asus X553MA-BPD07051 Optical Drive Replacement, Battery: шаг 1, изображение 1 из 2 Asus X553MA-BPD07051 Optical Drive Replacement, Battery: шаг 1, изображение 2 из 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 Optical Drive Replacement: шаг 2, изображение 1 из 1
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 Optical Drive Replacement: шаг 3, изображение 1 из 2 Asus X553MA-BPD07051 Optical Drive Replacement: шаг 3, изображение 2 из 2
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 Optical Drive Replacement: шаг 4, изображение 1 из 1
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
  5. Asus X553MA-BPD07051 Optical Drive Replacement: шаг 5, изображение 1 из 2 Asus X553MA-BPD07051 Optical Drive Replacement: шаг 5, изображение 2 из 2
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 Optical Drive Replacement: шаг 6, изображение 1 из 2 Asus X553MA-BPD07051 Optical Drive Replacement: шаг 6, изображение 2 из 2
    • Lift the battery up and remove it completely from the laptop.
  7. Asus X553MA-BPD07051 Optical Drive Replacement, Optical Drive: шаг 7, изображение 1 из 2 Asus X553MA-BPD07051 Optical Drive Replacement, Optical Drive: шаг 7, изображение 2 из 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
  8. Asus X553MA-BPD07051 Optical Drive Replacement: шаг 8, изображение 1 из 2 Asus X553MA-BPD07051 Optical Drive Replacement: шаг 8, изображение 2 из 2
    • Gently slide the optical drive out from the motherboard.
Заключение
Stephanie DeCarvalho
Участник с: 10/21/19
898 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 Участник UMass Dartmouth, Team S1-G4, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G4
3 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 371
