Введение
If your Asus ZenBook UX330U or UX330UA has a faulty trackpad, you may need to replace it. Before using this guide, look at the troubleshooting page located here for possible fixes that do not require any disassembly. This guide can be used to remove the trackpad for the ASUS ZenBook UX330U or UX330UA.
Before beginning any device disassembly, please power off and unplug your device.
Выберете то, что вам нужно
Before starting any device dissasembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin.
Remove the alligator clip at the end of the bracelet by simply pulling it off, to reveal the bullet connector.
Insert the bullet connector into the ground port of an outlet.
Remove the eight 3.1mm screws using the T5 Torx screwdriver bit.
Remove the longer 5.1mm screw using the T5 Torx screwdriver bit.
Use a Jimmy or a spudger to pry off the two rubber feet that are closest to the hinge.
Unscrew the two 5.6mm screws that were underneath the rubber feet using the Philips #0 screwdriver bit.
Remove the four 2.8mm screws from the motherboard ribbon connector using the Philips #0 screwdriver bit.
Remove the motherboard ribbon connector by pulling up on the metal ends with the blunt nose tweezers.
Pull back the silver battery connector lock with the blunt nose tweezers. This should slide back and should require minimal force.
Lift the battery connector vertically using the blunt nose tweezers to remove it from the socket.
Using the tweezers again, pull on the blue plastic tab with “TP” printed on it.
Remove the strip of tape by grabbing the end of it with the blunt nose tweezers and pulling back.
Remove the three 2.5 mm screws across the top of the trackpad with the Philips #0 screwdriver.
