Audiovox CR8030iE5 Backlight Replacement
Выберете то, что вам нужно
  1. Audiovox CR8030iE5 Backlight Replacement, Top-Casing: шаг 1, изображение 1 из 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Backlight Replacement: шаг 2, изображение 1 из 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Backlight Replacement: шаг 3, изображение 1 из 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Backlight Replacement: шаг 4, изображение 1 из 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Backlight Replacement: шаг 5, изображение 1 из 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Backlight Replacement, Backlight: шаг 6, изображение 1 из 1
    • Insert a Phillips #1 screwdriver into the corner, square, holes and push the backlight board up away from the plastic casing.
  7. Audiovox CR8030iE5 Backlight Replacement: шаг 7, изображение 1 из 1
    • Carefully, pull up on the board to remove it entirely from the plastic casing.
  8. Audiovox CR8030iE5 Backlight Replacement: шаг 8, изображение 1 из 1
    • Flip the backlight board over to view the underside.
  9. Audiovox CR8030iE5 Backlight Replacement: шаг 9, изображение 1 из 1
    • One by one, de-solder the four wires (two wires corresponding to each LED bulb) that attach the backlight to the board.
    • If you don't know how to solder, check out How To Solder and Desolder Connections.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  10. Audiovox CR8030iE5 Backlight Replacement: шаг 10, изображение 1 из 1
    • Remove the two LED light bulbs.
    • Insert each wire from the new LED bulbs into the respective holes.
  11. Audiovox CR8030iE5 Backlight Replacement: шаг 11, изображение 1 из 1
    • One by one, solder the backlight wires back into place.
Заключение
Nab Sengupta
Участник с: 04/18/13
55 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 10-39, Amido Spring 2013 Участник Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 323
