Выберете то, что вам нужно
Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
After prying open all of the anchoring points, the cover will lift off of the tablet.
Clean the soldering iron by melting a small amount of solder onto the soldering iron's tip. Then wiping the tip of the soldering iron on a damp sponge.
Place the desoldering wick on top of the existing solder ball.
Hold the soldering iron in place until the solder melts into the wick.
Repeat the same procedure on the remaining connector.
Pull the desoldered wires off of the circuit board. They should come off with little to no resistance. If they do not come off easily, remove more solder from the contact points with the wick.
Grip the wires and slowly pull the microphone out of its mounting point. Some force may be needed.
