Введение
This is a charging port replacement guide for the Beats Solo 3 Headphones, Model number A1796. Symptoms that suggest the need for a charging port replacement can be found on our troubleshooting page.
Выберете то, что вам нужно
Use a nylon or metal spudger to carefully remove the ear pad from the right ear cup.
Use a Phillips #00 screwdriver to remove the seven screws that hold the speaker in place.
After you desolder all wires you are able to remove and replace the charging port.
3 участников успешно повторили данное руководство.
