Введение
This is a motherboard replacement guide for the Beats Solo3 Headphones. The model number is A1796. This guide will show you how to safely and accurately remove and replace the motherboard from your headphones. The motherboard allows audio to be played wirelessly through any device such as a mobile phone. Symptoms that can result in a motherboard replacement can be found on our troubleshooting page.
Выберете то, что вам нужно
There will be three bundled cables attached to the motherboard. Carefully pull them out of each prong.
Use a Phillips #00 screwdriver to remove the four screws that hold the motherboard in place.
Еще один человек закончил это руководство.
