Введение
This guide is the detailed process of how to remove broken or damaged vibration motors on the Benoncool Gamepad for Nintendo Switch.
The Benoncool Gamepad has two vibration motors that frequently operate during gameplay to simulate high impact events. A broken or malfunctioning vibration motor is rather easy to identify when not getting the correct response or no response at all during these high impact events. Using this guide to replace your gamepad’s vibration motors will most likely fix your problem.
Выберете то, что вам нужно
Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
Gently separate the two halves of the controller.
Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
Lift the motherboard from the back case with the vibration motors and button boards attached.
Locate the two solder points corresponding to the malfunctioning vibrational motor.
