Behringer Eurolive B212D Power PCB Replacement
Выберете то, что вам нужно
  1. Behringer Eurolive B212D Power PCB Replacement, Electronics Box: шаг 1, изображение 1 из 1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
    Спросите у FixBot
    Добавить комментарий
  2. Behringer Eurolive B212D Power PCB Replacement: шаг 2, изображение 1 из 1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
    Спросите у FixBot
  3. Behringer Eurolive B212D Power PCB Replacement, Electronics Box: шаг 3, изображение 1 из 3 Behringer Eurolive B212D Power PCB Replacement, Electronics Box: шаг 3, изображение 2 из 3 Behringer Eurolive B212D Power PCB Replacement, Electronics Box: шаг 3, изображение 3 из 3
    • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
    • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
    • You should have removed a total of 7 machine screws and 2 washers.
    • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
    Спросите у FixBot
  4. Behringer Eurolive B212D Power PCB Replacement: шаг 4, изображение 1 из 1
    • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
    Спросите у FixBot
  5. Behringer Eurolive B212D Power PCB Replacement: шаг 5, изображение 1 из 3 Behringer Eurolive B212D Power PCB Replacement: шаг 5, изображение 2 из 3 Behringer Eurolive B212D Power PCB Replacement: шаг 5, изображение 3 из 3
    • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
    • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
    • Snake the clip head through the hole in the metal electronics box casing.
    Спросите у FixBot
  6. Behringer Eurolive B212D Power PCB Replacement, Power & Control Panel: шаг 6, изображение 1 из 2 Behringer Eurolive B212D Power PCB Replacement, Power & Control Panel: шаг 6, изображение 2 из 2
    • Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
    Спросите у FixBot
  7. Behringer Eurolive B212D Power PCB Replacement: шаг 7, изображение 1 из 2 Behringer Eurolive B212D Power PCB Replacement: шаг 7, изображение 2 из 2
    • Caution: The circuit board contains many capacitors that could cause serious injury if touched. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Rotate the back panel so you can view the interior; note the three wires attached.
    • Remove the wires to you can fully remove the back panel.
    Спросите у FixBot
  8. Behringer Eurolive B212D Power PCB Replacement, Power PCB: шаг 8, изображение 1 из 3 Behringer Eurolive B212D Power PCB Replacement, Power PCB: шаг 8, изображение 2 из 3 Behringer Eurolive B212D Power PCB Replacement, Power PCB: шаг 8, изображение 3 из 3
    • Remove the 4 indicated 7/32" long machine screws with a #1 phillips head screwdriver.
    • Remove the box containing the power PCB.
    Спросите у FixBot
  9. Behringer Eurolive B212D Power PCB Replacement: шаг 9, изображение 1 из 2 Behringer Eurolive B212D Power PCB Replacement: шаг 9, изображение 2 из 2
    • There are 4 remaining 7/32" long machine screws holding the power PCB to the box which contains it; remove these with a #1 phillips head screwdriver.
    • Remove the power PCB.
    Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Troy W. Weber
Участник с: 03/29/12
1 506 Репутация
Автор 6 руководств
14 Комментарии к руководству
This PCB does not convert electricity, and is rarely what fails. AC leaves this board and gets converted to DC at the rectifier bridge, which is part of the main amp PCB. This main amp board is where 99.9% of issues arise...
Gabriel Talamantes - Ответить Поделиться
Do you know where I can find replacement boards for this speaker? It takes about 20 times of cycling the power button for it to finally come on. Can't seem to find parts anywhere. May not be financially smart to replace the board, but if it's not that expensive, I feel it's worth it.
Justin - Ответить Поделиться
Hi. Why dont you fix the board?
riaandd - Ответить Поделиться
Has anyone got a circuit diagram for the power board. Is it a switch mode power supply - the power plug indicates 240V or 110 V AC which would normally indicate it uses a switch mode power supply at the front end
Jonathon - Ответить Поделиться
my fuse holder the plastic broke because there is not enough pressure to hold in the fuse and turns on and off
Jeffrey Martinez - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 23
За последние 30 дней: 109
За всё время: 22,685
