Введение
The trigger/switch board is an internal component and will require disassembly of the screwdriver casing. Due to disassembly of the casing, you will be required to use a few special tools listed in the outer casing replacement guide. Consult the outer casing replacement guide for instructions on removing the casing. Also, use caution when working on the screwdriver internally - always unplug the battery before replacing any components. This guide will also require a soldering iron and basic soldering skills for replacing the trigger/switch board.
Выберете то, что вам нужно
Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
Pry on the seam as shown with a Spudger, in order to get the top casing loose.
Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
Locate the negative terminal of the battery.
Remove the negative (black) wire by pulling back gently.
Gently pull up on the end of the battery closest to the negative terminal. Pulling the battery up should reveal the positive (red) wire located on the opposite end of the battery.
To free battery, gently pull back on the positive (red) wire.
Set battery aside in a safe place.
Locate the trigger/switch board located directly behind the trigger.
Gently pull the trigger directly up from it's seated position on the screwdriver.
The trigger should be freed from the casing.
Inspect the trigger contacts located on the backside of the trigger for any corrosion or damage.
Inspect the trigger contacts located on the board for any corrosion or damage.
To remove the trigger/switch board, gently pull the board directly up - away from casing.
Locate the plug wire with red and white wires leading the trigger/switch board.
Remove the plug wire from the trigger/switch board by gently pulling back on wire.
The white adhesive will need to be removed with a plastic spudger.
Gently scrape away all of the white adhesive until wires are fully exposed on the trigger/switch board.
To replace trigger/switch board, use a soldering iron to remove the four soldering joints shown.
