Black and Decker TR1278B Circuit Board Replacement
Выберете то, что вам нужно
  1. Black and Decker TR1278B Circuit Board Replacement, Top Cover: шаг 1, изображение 1 из 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Circuit Board Replacement: шаг 2, изображение 1 из 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Circuit Board Replacement: шаг 3, изображение 1 из 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Circuit Board Replacement: шаг 4, изображение 1 из 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Circuit Board Replacement: шаг 5, изображение 1 из 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Circuit Board Replacement, Circuit Board: шаг 6, изображение 1 из 1
    • Locate the circuit board inside front cover.
  7. Black and Decker TR1278B Circuit Board Replacement: шаг 7, изображение 1 из 2 Black and Decker TR1278B Circuit Board Replacement: шаг 7, изображение 2 из 2
    • Use a Phillips head #2 screwdriver to unscrew all five screws that attach the circuit board to the top cover.
    • Remove the circuit board.
    • Inspect the circuit board for any burnt or otherwise damaged components.
    • Use a soldering kit to unsolder the damaged component.
    • Once the damaged component has been unsoldered from the circuit board, remove (and replace) it.
    • iFixit Soldering Guide.
Заключение
Brea-Monique
Участник с: 02/15/17
399 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 8-1, Eyestone Spring 2017 Участник USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 членов
Автор 5 руководств
1 Комментарий к руководству
These instructions are wrong. The screw and clear plastic piece seen in step 7 doesn't go there it actually secures the power wire at the base of the toaster and technically isn't needed. The 5th hole is for the plastic catch of the heat selector knob.
Mr. S - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 34
За всё время: 1,328
