Введение
If you do not see any broken or missing keys on your BlackBerry Bold but when you press a button there is no response, the keyboard membrane may need replacing. Replacing this membrane on any device can be difficult, but by following the steps in this guide you will have a new keyboard membrane installed in no time.
Выберете то, что вам нужно
Remove the battery by prying the bottom of the battery upward.
Once the battery is angled up, pull it away from the top of the device.
Slide the SIM card from underneath the holding bracket upward toward the battery connector pins.
Use your T5 Torx screwdriver to remove the two black 5.57mm Torx head screws underneath the keyboard.
Use the plastic opening tool to remove the frame of your device.
Once the case is loosened from the device, slide the case away from the top of the phone.
Gently lift the bottom of the keyboard upward.
Pull the keyboard away from the bottom of the LCD display and lift upward.
Gently pry up the ribbon connector at the top of the phone with a plastic opening tool.
Remove the top two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
Lift the clear plastic cover directly upward.
Grip the motherboard by the screen
Lift the board away from the base of the housing and vertically up.
Use a conventional hair dryer to heat up the keyboard membrane.
On medium or low heat evenly heat up the membrane in the range of 5 to 10 minutes
Align the new keyboard membrane with gold conduits and press down onto circuit board.
Еще один человек закончил это руководство.
