BlackBerry KeyONE partial Disassembly
Выберете то, что вам нужно
  1. BlackBerry KeyONE partial Disassembly, Remove top cover: шаг 1, изображение 1 из 1
    • Carefully remove the top plastic cover. It is held in place by adhesive.
    Спросите у FixBot
  2. BlackBerry KeyONE partial Disassembly, Remove top frame: шаг 2, изображение 1 из 2 BlackBerry KeyONE partial Disassembly, Remove top frame: шаг 2, изображение 2 из 2
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
    Спросите у FixBot
  3. BlackBerry KeyONE partial Disassembly, Remove back cover: шаг 3, изображение 1 из 1
    • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
    Спросите у FixBot
  4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: шаг 4, изображение 1 из 2 BlackBerry KeyONE partial Disassembly, Disconnect Battery: шаг 4, изображение 2 из 2
    • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
    Спросите у FixBot
  5. BlackBerry KeyONE partial Disassembly: шаг 5, изображение 1 из 1
    • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
    • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
    Спросите у FixBot
  6. BlackBerry KeyONE partial Disassembly, Remove top cover: шаг 6, изображение 1 из 1
    • Remove the three Philipps #0 screws securing the upper cover and remove it.
    Спросите у FixBot
  7. BlackBerry KeyONE partial Disassembly: шаг 7, изображение 1 из 1
    • Unplug the remaining ribbon cables
    • Remove the last three Philipps #0 screws securing the Motherbard.
    • Now you should be able to replace most components.
    • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
    • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
    • Don't forget to remove the sim-tray if you're removing the motherboard.
    Спросите у FixBot
Заключение
15 человек успешно провели ремонт по этому руководству.
raven
Участник с: 09/02/15
1 110 Репутация
Автор 4 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 74
За всё время: 10,821
