Введение
Here we show how to replace the battery in the Bosch IXO cordless screwdriver (2nd generation) when the power or battery duration is no longer given.
Выберете то, что вам нужно
Loosen 4 screws size Torx T10. The screw size is identical for all four screws.
Loosen the nameplate on the bottom of the screwdriver and set it aside so that the right housing part can be removed in the next step.
The housing halves now lie loosely on top of each other. Lift the right housing half upwards and set it aside.
Heat the cables at both pole ends with a soldering iron and detach them.
Connect the side of the new battery with the white ring (positive pole +) to the red cable. Solder the blue cable to the other side (without the white ring).
To reassemble the device, follow the steps in reverse order
6 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
2 Комментариев
Danke für die glasklaren Anweisungen!
Sehr gerne, freut mich, dass es geklappt hat :-)
BenZ78 -
