Введение
This guide will aid you in replacing the clasp to fix a broken bracelet. It will walk you through how to open and close a jump ring and then how to reattach the bracelet clasp. By doing so, you will be able to reattach a bracelet clasp on most types of bracelets for little to no cost.
Выберете то, что вам нужно
The clasp and metal ring (jump ring) need to be replaced.
Replace the jump ring first and then the clasp.
Be sure the correct clasp for the bracelet is present.
Use the needle-nose pliers to grasp the jump ring on its side, away from the break in the ring.
Open the jump ring with the needle-nose pliers by holding one side of the ring with the pliers and the other side with your fingers.
Hold the clasp in one hand and the pliers in the other.
Attach the new clasp to the opened jump ring being held by the needle-nose pliers by sliding the jump ring through all corresponding rings, including the clasp.
Use the needle-nose pliers to close the jump ring by squeezing the two arms of the ring together.
Use the needle-nose pliers to tighten the jump ring, with the jump ring perpendicular to the two arms of the pliers.
Test that the clasp and jump ring are properly attached by holding the bracelet from the clasp and suspending the rest of the bracelet.
5 человек успешно провели ремонт по этому руководству.
