Введение
If the buttons on your speaker are not working, they may need to be replaced. Use this guide to replace the button module on your Braven BRV-X.
Выберете то, что вам нужно
Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
Pry open the second plate holding in the speaker using a spudger around all sides.
Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
Cut the 22 gauge wire attached in the corner.
Solder the new speaker plate during reassembly.
Remove three 0.7 cm screws from the button module(s) using the Phillips #00 screwdriver.
