Brother MFC-490CW Print head Replacement
Выберете то, что вам нужно
  1. Brother MFC-490CW Print head Replacement, Remove screws holding the front panel: шаг 1, изображение 1 из 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Print head Replacement, Unplug the panel from the rest of the printer: шаг 2, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Unplug the panel from the rest of the printer: шаг 2, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Unplug the panel from the rest of the printer: шаг 2, изображение 3 из 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Print head Replacement, Separate the arm holding scanner unit: шаг 3, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Separate the arm holding scanner unit: шаг 3, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Separate the arm holding scanner unit: шаг 3, изображение 3 из 3
    • Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit.
    • Lift the scanner unit.
    • Gently twist the top portion of the arm.
    • The top portion should release from the scanner unit.
    • Rotate the arm approximately 45 degrees to remove the bottom portion of the arm from the device.
  4. Brother MFC-490CW Print head Replacement, Remove the scanner unit from the device: шаг 4, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Remove the scanner unit from the device: шаг 4, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Remove the scanner unit from the device: шаг 4, изображение 3 из 3
    • Slide the unit either to the left or right and begin to push the unit away from the device.
    • Once one hinge is separated from the device, begin to remove the other hinge from the device.
    • Gently place the unit on the work surface.
    • Be careful not to pull too hard. the wires connecting the unit to the device must be removed.
  5. Brother MFC-490CW Print head Replacement, Remove left wire panels: шаг 5, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Remove left wire panels: шаг 5, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Remove left wire panels: шаг 5, изображение 3 из 3
    • While it is not necessary to use a prying tool, using one may make it easier to lift the panels.
    • Starting from the back of the printer, use the exposed portion of the panel to gently pry the panel up from the printer.
  6. Brother MFC-490CW Print head Replacement, Remove right wire panel: шаг 6, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Remove right wire panel: шаг 6, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Remove right wire panel: шаг 6, изображение 3 из 3
    • From the back of the device, use the exposed portion of the panel to begin to lift the panel away from the device.
  7. Brother MFC-490CW Print head Replacement, Removing left set of power cables: шаг 7, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Removing left set of power cables: шаг 7, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Removing left set of power cables: шаг 7, изображение 3 из 3
    • Before removing the cables, create a diagram of the locations of the different cables with some tape or Post-Its.
    • Remove the three power cables that connect the scanner to the motherboard.
  8. Brother MFC-490CW Print head Replacement, Remove the ground wire: шаг 8, изображение 1 из 2 Brother MFC-490CW Print head Replacement, Remove the ground wire: шаг 8, изображение 2 из 2
    • Use a Phillips #2 screwdriver to remove the 12.1 mm screw to remove the ground wire.
  9. Brother MFC-490CW Print head Replacement, Remove data cable: шаг 9, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Remove data cable: шаг 9, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Remove data cable: шаг 9, изображение 3 из 3
    • Gently pull the data cable away from the motherboard.
    • Slide the cable out of the slots to remove the cable from the device.
    • The scanner unit is now separated. Place the unit and ground screw in a safe part of the workspace until needed for re-assembly.
  10. Brother MFC-490CW Print head Replacement, Remove front screws of the device cover: шаг 10, изображение 1 из 1
    • Use the Phillips #2 screwdriver to remove the three 14.1 mm screws.
    • Use the Phillips #2 screwdriver to remove the 12.1 mm screw.
  11. Brother MFC-490CW Print head Replacement, Remove the paper tray: шаг 11, изображение 1 из 1
    • Pull the paper tray away from the device.
  12. Brother MFC-490CW Print head Replacement, Remove center screw near the USB and ethernet ports: шаг 12, изображение 1 из 1
    • Use the Phillips #2 screwdriver to remove the 8 mm screw at the center of the device.
  13. Brother MFC-490CW Print head Replacement, Remove rear panel screws: шаг 13, изображение 1 из 1
    • Use the Phillips #2 screwdriver to remove the two 14.1 mm screws holding the panel in place.
  14. Brother MFC-490CW Print head Replacement, Remove red power cable: шаг 14, изображение 1 из 1
    • This cable needs to be removed to allow the removal of the device cover.
    • Gently remove the red power cable from the motherboard.
  15. Brother MFC-490CW Print head Replacement, Remove paper jam clear cover: шаг 15, изображение 1 из 2 Brother MFC-490CW Print head Replacement, Remove paper jam clear cover: шаг 15, изображение 2 из 2
    • Gently push the upper-left tab of the cover and separate the hinged portion of the cover from the rest of the device.
    • Once one side is free, slide the other side away from the device.
    • Pull the cover away from the device.
  16. Brother MFC-490CW Print head Replacement, Remove the device cover: шаг 16, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Remove the device cover: шаг 16, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Remove the device cover: шаг 16, изображение 3 из 3
    • Using a spudger, loosen the two clipped portions of the cover located at the back-center of the cover.
    • Once the clips are free the rest of the cover can be lifted up and away from the device.
  17. Brother MFC-490CW Print head Replacement, Release the clear print head guide wire: шаг 17, изображение 1 из 2 Brother MFC-490CW Print head Replacement, Release the clear print head guide wire: шаг 17, изображение 2 из 2
    • Gently pull the wire to the left so the end of the wire is released.
    • Slide the wire away from the top of the print head unit.
  18. Brother MFC-490CW Print head Replacement, Releasing the print head from the carriage: шаг 18, изображение 1 из 2 Brother MFC-490CW Print head Replacement, Releasing the print head from the carriage: шаг 18, изображение 2 из 2
    • Using a spudger, press down on the plastic housing of the carriage that the print head rests on.
    • Slide the print head to the left of the device.
  19. Brother MFC-490CW Print head Replacement, Removing the print head from the rails.: шаг 19, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Removing the print head from the rails.: шаг 19, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Removing the print head from the rails.: шаг 19, изображение 3 из 3
    • Slide the print head until it is at the end of the rail.
    • Push the print head unit towards the back of the device and lift the unit from the back rail.
    • Gently release the other end of the print head to remove it from the front rail.
  20. Brother MFC-490CW Print head Replacement, Release the print heat conveyor: шаг 20, изображение 1 из 1
    • Using the spudger, press the spring section of the white pulley.
    • Release the conveyor from the pulley while the spring is still compressed.
    • Remove the conveyor from the gear on the other side of the device.
    • Optional: Slide the conveyor off the print head.
  21. Brother MFC-490CW Print head Replacement, Opening the top print head cover.: шаг 21, изображение 1 из 1
    • Squeeze the ends of the cover, then release the cover, revealing the processor unit.
  22. Brother MFC-490CW Print head Replacement, Remove the data cable from the print head processing unit.: шаг 22, изображение 1 из 2 Brother MFC-490CW Print head Replacement, Remove the data cable from the print head processing unit.: шаг 22, изображение 2 из 2
    • Slide the black cap away from the port.
    • Slide the data cable out of the port.
  23. Brother MFC-490CW Print head Replacement, Remove print head processor unit: шаг 23, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Remove print head processor unit: шаг 23, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Remove print head processor unit: шаг 23, изображение 3 из 3
    • Lift the processor out of the print head.
    • Slide the cables attached to the processor away from the print head unit.
  24. Brother MFC-490CW Print head Replacement, Remove the inkjet nozzle unit.: шаг 24, изображение 1 из 3 Brother MFC-490CW Print head Replacement, Remove the inkjet nozzle unit.: шаг 24, изображение 2 из 3 Brother MFC-490CW Print head Replacement, Remove the inkjet nozzle unit.: шаг 24, изображение 3 из 3
    • Remove the metal clip holding the nozzle unit.
    • Lift the unit from the rest of the print head unit.
Заключение
To reassemble your device, follow these instructions in reverse order
28 участников успешно повторили данное руководство.
Henry Cho
Участник с: 10/29/14
1 037 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 4-4, Miles Fall 2014 Участник UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 членов
Автор 8 руководств
9 Комментариев
I did follow this guide for a Brother MFC-6490CW although they are not identical it was very helpful for me to follow up to the removal of the print head as I only wanted to clean some blocked nozzles but the principle was the same
crystalbic - Ответить
*Note my new print head did not come with the rubber gasket that the sits between the inkjet nozzle unit and the new print head, remember to look for it and move it to the new one.
Kat - Ответить
Also after putting the new print head on the inkjet nozzle unit lines / tubing is full of air and needs to be primed in order for the ink to flow again because there is a huge air bubble in the print head.
To do this best way is to (if it is back together without pulling it apart):
1) Start the printer to print a page and when it has started while the paper is still under the print head disconnect the power that way the print head is in the middle and not parked on the right side.
2)Put a couple pieces blotting paper or in my case I used folded up paper towel under the print head
3)Take out all the ink cartridges and using a large syringe and a small tube full of a cleaning solution or use a kit that u can buy online.
Kat - Ответить
*Caught off guard not knowing I would need to do this I improvised breaking an old ink cartridge and cutting off the ink nozzle flush with the cartridge so i had the female rubber grommet end and about a ½" piece of plastic tube, I then cut off a bit of spare air hose for my fish tank and got an empty squeeze sauce bottle with a long nozzle and put in some alcohol. I put the plastic tube into the female end and the other end onto the sauce bottle.
Connect it to where the ink cartridge goes in and push the fluid through the line till you see ink / fluid come out of the print head, then do the other lines possibly changing the blotting paper in between colors depending how much mess it makes
Kat - Ответить
Then replace the ink cartridges and run a cleaning or to and print a few full color pages .... dont panic if the colors dissapears for a while and it comes out blank because the alcohol needs to fully come out but the new ink will flow up the tubes after the alcohol .... this actually took quite a while to start printing colors again but it did get there and a few more cleans once it was and it was fantastic
The Printer has not printed as well for years :)
Kat - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 44
За последние 30 дней: 137
За всё время: 38,949
