Bullnose Tile Replacement
Выберете то, что вам нужно
  1. Bullnose Tile Replacement, Bullnose Tile: шаг 1, изображение 1 из 1
    • Collect all bullnose tile pieces that have fallen off into one place.
    Спросите у FixBot
  2. Bullnose Tile Replacement: шаг 2, изображение 1 из 1
    • Locate the place where the bullnose tiles previously were (where the tiles broke off from).
    Спросите у FixBot
  3. Bullnose Tile Replacement: шаг 3, изображение 1 из 2 Bullnose Tile Replacement: шаг 3, изображение 2 из 2
    • Align any tiles that may have broken.
    Спросите у FixBot
  4. Bullnose Tile Replacement: шаг 4, изображение 1 из 1
    • To check you have all the tiles in the correct alignment, place the bullnose tiles along the edge that they broke off of to make sure they fit.
    • Remember, the standard size tiles (typically the longer ones) should be placed towards the center with the remaining tiles (typically the shorter ones) on the edge.
    Спросите у FixBot
  5. Bullnose Tile Replacement: шаг 5, изображение 1 из 1
    • To double check the order, find the perfect fit between the tile and the remaining grout (where the tile lies flush with the grout).
    Спросите у FixBot
  6. Bullnose Tile Replacement: шаг 6, изображение 1 из 1
    • Now that you are sure, flip the tiles over so their underside is accessible.
    Спросите у FixBot
  7. Bullnose Tile Replacement: шаг 7, изображение 1 из 1
    • Sand off any extra bits attached to the tile that will impact reattachment (for example, general debris or unsavable tile slivers).
    • Keep in mind that some texture is good for the later reattachment, so sand sparingly.
    Спросите у FixBot
  8. Bullnose Tile Replacement: шаг 8, изображение 1 из 1
    • Clean off your space to avoid accidentally gluing grime back onto your tiles.
    Спросите у FixBot
  9. Bullnose Tile Replacement: шаг 9, изображение 1 из 1
    • Prepare about three strips of painter's tape per complete tile or one per broken tile piece.
    • These tape strips will be used to hold the tiles in place while the glue dries, so make each one long enough to secure tightly over both sides of the tile.
    Спросите у FixBot
  10. Bullnose Tile Replacement: шаг 10, изображение 1 из 1
    • Apply Gorilla Glue generously to the interior sides of the tile, as well as the corner edge that will be pressed into the tile.
    • Ensure the room in which this project is taking place is well ventilated.
    Спросите у FixBot
  11. Bullnose Tile Replacement: шаг 11, изображение 1 из 1
    • Apply glue generously to the surface you are attempting to reattach the tile to.
    • Make sure to glue one tile area at a time to avoid premature glue drying.
    Спросите у FixBot
  12. Bullnose Tile Replacement: шаг 12, изображение 1 из 1
    • Press and hold your glued tile into your glued surface.
    Спросите у FixBot
  13. Bullnose Tile Replacement: шаг 13, изображение 1 из 1
    • Use your painters tape to hold the glued tile and surface together while the glue dries.
    Спросите у FixBot
  14. Bullnose Tile Replacement: шаг 14, изображение 1 из 1
    • Continue these last five steps for all the bullnose tiles you are reattaching.
    • The glue will take 1-2 hours to dry.
    Спросите у FixBot
  15. Bullnose Tile Replacement: шаг 15, изображение 1 из 1
    • Use a paper towel to clean off as much dripping glue as you can.
    • Do not worry if you miss some; later there will be a more thorough glue cleanup step once the glue is dried.
    Спросите у FixBot
  16. Bullnose Tile Replacement: шаг 16, изображение 1 из 1
    • While drying, the glue may foam and eventually become firm when dried. This is normal. This is how industrial grade glue gets to as much surface as possible for the best attachment.
    Спросите у FixBot
  17. Bullnose Tile Replacement: шаг 17, изображение 1 из 1
    • Once the glue is dry, remove the painters tape.
    • The tape directly touching the glue will be harder to remove, so do not focus on removing those pieces right now. They will be removed later alongside dried excess glue.
    Спросите у FixBot
  18. Bullnose Tile Replacement: шаг 18, изображение 1 из 2 Bullnose Tile Replacement: шаг 18, изображение 2 из 2
    • Use your razor cutter to chip off the excess dried glue.
    • Remember to get the glue that has dripped past your working area as well.
    • Make sure you are never in the cutting path of the blade.
    Спросите у FixBot
  19. Bullnose Tile Replacement: шаг 19, изображение 1 из 1
    • Use your standard scraper to remove as much dried glue that found its way between your tiles. This space should be made as clear as possible for grout.
    Спросите у FixBot
  20. Bullnose Tile Replacement: шаг 20, изображение 1 из 1
    • Squeeze your grout into the gap.
    • You are done when the grout pushes out all three exposed sides. This is how you know that the gap is filled completely.
    Спросите у FixBot
  21. Bullnose Tile Replacement: шаг 21, изображение 1 из 1
    • Apply grout alongside the exposed edges of the tiles as well. Use the grout that remains from the original design to mark where yours should go.
    Спросите у FixBot
  22. Bullnose Tile Replacement: шаг 22, изображение 1 из 1
    • Wipe off the excess grout with a damp paper towel.
    Спросите у FixBot
  23. Bullnose Tile Replacement: шаг 23, изображение 1 из 1
    • Wait for the grout to dry and SUCCESS! Enjoy your reattached bullnose tiles!
    Спросите у FixBot
Финишная прямая
Harper Shelby
Участник с: 01/09/26
337 Репутация
1 руководство автора
Команда
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 29
За всё время: 33
