CASIO fx-300ES Plus Scientific Calculator Battery Replacement
Выберете то, что вам нужно
  1. CASIO fx-300ES Plus Scientific Calculator Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn off the calculator by pressing the [Shift] button.
    • Press the [AC][OFF] button.
  2. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: шаг 2, изображение 1 из 1
    • Flip the calculator over so that the back panel faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • If the screw is not unfastening, do not force it because it can strip the screw. If the screw is already stripped see the How to Remove a Stripped Screw guide.
  3. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: шаг 3, изображение 1 из 1
    • Remove the battery cover.
  4. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: шаг 4, изображение 1 из 1
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to pry out the battery.
    • Be gentle when removing the battery to avoid damaging it.
  5. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: шаг 5, изображение 1 из 2 CASIO fx-300ES Plus Scientific Calculator Battery Replacement: шаг 5, изображение 2 из 2
    • Place the new LR44 alkaline battery into the calculator.
    • Be sure that the + sign is at the bottom.
  6. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: шаг 6, изображение 1 из 1
    • Reattach the battery cover.
    • Insert the screw for the battery cover using a Phillips #0 screwdriver.
  7. CASIO fx-300ES Plus Scientific Calculator Battery Replacement: шаг 7, изображение 1 из 1
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
Заключение
You have now successfully replaced a Casio FX-300ES battery.
2 человек успешно провели ремонт по этому руководству.
Maha
Участник с: 07/08/20
255 Репутация
1 руководство автора
Команду
York University, Team S1-G22, Allen Summer 2020 Участник York University, Team S1-G22, Allen Summer 2020
YORK-ALLEN-SU20S1G22
1 член
Автор 5 руководств
1Комментарий к руководству
Below is a detailed video showing the battery replacement process.
https://youtu.be/I7pR-_Ra5W8
Tomatoman - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 11
За последние 7 дней: 74
За последние 30 дней: 335
За всё время: 34,776
