Canon EOS Rebel T3 Top Cover Replacement
Выберете то, что вам нужно
  1. Canon EOS Rebel T3 Top Cover Replacement, I/F Terminal Cover: шаг 1, изображение 1 из 3 Canon EOS Rebel T3 Top Cover Replacement, I/F Terminal Cover: шаг 1, изображение 2 из 3 Canon EOS Rebel T3 Top Cover Replacement, I/F Terminal Cover: шаг 1, изображение 3 из 3
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T3 Top Cover Replacement, Back Cover: шаг 2, изображение 1 из 2 Canon EOS Rebel T3 Top Cover Replacement, Back Cover: шаг 2, изображение 2 из 2
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
  3. Canon EOS Rebel T3 Top Cover Replacement: шаг 3, изображение 1 из 2 Canon EOS Rebel T3 Top Cover Replacement: шаг 3, изображение 2 из 2
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
  4. Canon EOS Rebel T3 Top Cover Replacement: шаг 4, изображение 1 из 3 Canon EOS Rebel T3 Top Cover Replacement: шаг 4, изображение 2 из 3 Canon EOS Rebel T3 Top Cover Replacement: шаг 4, изображение 3 из 3
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
  5. Canon EOS Rebel T3 Top Cover Replacement, Front Cover: шаг 5, изображение 1 из 1
    • Remove the following screws on the front of the camera.
    • Two M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T3 Top Cover Replacement: шаг 6, изображение 1 из 1
    • On the bottom of the camera, remove the following screws:
  7. Canon EOS Rebel T3 Top Cover Replacement: шаг 7, изображение 1 из 3 Canon EOS Rebel T3 Top Cover Replacement: шаг 7, изображение 2 из 3 Canon EOS Rebel T3 Top Cover Replacement: шаг 7, изображение 3 из 3
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
  8. Canon EOS Rebel T3 Top Cover Replacement, Top Cover: шаг 8, изображение 1 из 2 Canon EOS Rebel T3 Top Cover Replacement, Top Cover: шаг 8, изображение 2 из 2
    • Push up and slide off the eyepiece.
    • Remove the following screws:
    • Two M1.7x2.5mm JIS #000 screws
    • One M1.7x3.6mm JIS #000 diopter screw
  9. Canon EOS Rebel T3 Top Cover Replacement: шаг 9, изображение 1 из 1
    • Remove the following screws on the top of the camera:
    • One M1.7x2.5mm JIS #000 screw
  10. Canon EOS Rebel T3 Top Cover Replacement: шаг 10, изображение 1 из 2 Canon EOS Rebel T3 Top Cover Replacement: шаг 10, изображение 2 из 2
    • Disconnect the microphone cable from the main PCB board.
    • Position a flathead 2.5mm screwdriver between the main PCB board connector and the microphone connector.
    • Gently wiggle the flathead screwdriver back and forth until the microphone connector comes free.
    • If you do not have a flathead 2.5mm screwdriver, another similarly sized flathead screwdriver should work.
  11. Canon EOS Rebel T3 Top Cover Replacement: шаг 11, изображение 1 из 3 Canon EOS Rebel T3 Top Cover Replacement: шаг 11, изображение 2 из 3 Canon EOS Rebel T3 Top Cover Replacement: шаг 11, изображение 3 из 3
    • Locate the mode dial ribbon cable on the main PCB board.
    • Use a plastic spudger tool to carefully lift up the locking tab.
    • Use caution when handling ribbon connectors and their connectors.
    • Use a pair of angled tweezers to pull the ribbon cable out of the connector.
  12. Canon EOS Rebel T3 Top Cover Replacement: шаг 12, изображение 1 из 2 Canon EOS Rebel T3 Top Cover Replacement: шаг 12, изображение 2 из 2
    • Gently lift up the top cover.
    • There are still several cables connecting the top cover to the camera. Be careful to not pull on these cables while lifting up the top cover.
    • Set the top cover down, making sure not to pull on the cables still attached.
Заключение
Прикрепленные документы
Zephosk
Участник с: 09/26/24
4 741 Репутация
Автор 29 руководств
Команду
LGBTQ Technicians Участник LGBTQ Technicians
Community
33 членов
Автор 68 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 56
