Canon PowerShot SD780 IS Flash Capacitor Replacement
Выберете то, что вам нужно
    • Begin by making sure the camera is turned off and the battery has been removed to avoid any shock injuries.
  1. Canon PowerShot SD780 IS Flash Capacitor Replacement: шаг 2, изображение 1 из 2 Canon PowerShot SD780 IS Flash Capacitor Replacement: шаг 2, изображение 2 из 2
    • Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver.
    • Keep track of where each screw came from in order to avoid complications during the reassemble process.
    • The screws highlighted by the red square in the second image (on the left side in the first image) are 2.0 mm long.
  2. Canon PowerShot SD780 IS Flash Capacitor Replacement: шаг 3, изображение 1 из 1
    • Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
  3. Canon PowerShot SD780 IS Flash Capacitor Replacement: шаг 4, изображение 1 из 1
    • Remove the screw on the far left hand side of the camera.
  4. Canon PowerShot SD780 IS Flash Capacitor Replacement: шаг 5, изображение 1 из 1
    • Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
  5. Canon PowerShot SD780 IS Flash Capacitor Replacement: шаг 6, изображение 1 из 1
    • Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
  6. Canon PowerShot SD780 IS Flash Capacitor Replacement: шаг 7, изображение 1 из 1
    • You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
Заключение
Еще один человек закончил это руководство.
Arlene Ale
Участник с: 03/13/14
455 Репутация
Автор 4 руководств
Команда
New Mexico State, Team 1-5, Easley Spring 2014 Участник New Mexico State, Team 1-5, Easley Spring 2014
NMSU-EASLEY-S14S1G5
2 членов
Автор 4 руководств
Один комментарий
what is the number for the replacement battery?
peterprosser - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 897
