Введение
The speaker is on the underside of the top casing and will involve some minor technical skills.
Инструменты
Запчасти
Детали не указаны.
Locate and remove the three screws attaching the side panel.
Remove the side paneling and the two remaining screws attached to the frame of the camera.
Open the battery cover.
Locate and remove the four screws inside.
One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
Close the battery cover.
Open the "DIGITAL AV OUT" door on the camera.
Remove the three screws. The door can be removed from the camera.
Gripping the sides of the top cover, gently pull apart the top cover from the camera.
Using a thin tool, push the black attachment away from the white connection piece to detach the connector ribbon.
Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
You may need to use a bit of force as the speaker be glued in to the top casing.
