Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
Twist the top burr to the left counter clockwise.
Flip entire device upside down.
Remove two rubber coverings on the back of the device.
Lift the metal outside casing off the black base.
Flip the outside casing forward so you have access to the inside of it.
Remove one 11.59mm T10 screw.
Let the green wire fall, or place somewhere so it doesn't get in the way.
Strip the two wires of their black covering connecting them to the black box.
Solder the two cords holding in the blue and white wire in the black timer box.
3 участников успешно повторили данное руководство.
4 Комментариев
do you know where I can get a new black timer box?
Where can I purchase a timer/on switch?
Same question here, where can I buy this part?
Just piling on,has anyone found where to buy the Timer switch?
