Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Выберете то, что вам нужно
Flip the PS4 upside-down with the back side facing towards you.
Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
Remove the four 7.2 mm Torx security screws on the back of the PS4.
Use your thumbs to lift the lower case up and off the PS4.
Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
