Введение
This guide will help you get your speaker working again if it has stopped working. All you need is the necessary tools and some time and your device's speaker will work again!
Выберете то, что вам нужно
Insert your Plastic Opening Tool into the crease between the front panel and back panel.
Slide the Opening Tool around the entire device. As you progress, you should see the device open.
Carefully turn the device over.
Lay the back panel aside so you can see the device's parts.
