Введение
This guide will take you step by step through the process of replacing your speakers.
Выберете то, что вам нужно
Remove the top (button side) rubber cover using your hands.
Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
Separate the wires so that each white cap distinctly has a single red and single black wire coming out of it.
Disconnect the two sets of wires by pulling on the wires until the white cap detaches from the circuit board.
Detach the solder points on each gold speaker in order to release and remove them.
