Введение
Follow this guide to replace the upper drive chain on a 2018 Classen Sod Cutter model HSC18AHD.
Выберете то, что вам нужно
Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
Flip the gas shutoff switch next to the motor to the left into the off position.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
Slide the cutter blade out from under the machine to remove it.
Шаг 8 Remove the chain guard
Careful: steps 8-10 are sourced from a guide that's marked as in-progress.
Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
Carefully tilt the sod cutter on its side.
Use a 9/16 inch socket to remove the nut securing the chain guard.
Use a 1/2 inch socket to remove the two bolts securing the upper chain guard to the frame.
Use a 3/4 inch socket to loosen the bolt securing the tensioner sprocket until it can freely slide up and down the bracket.
Roll the machine to turn the chain until the master link is accessible.
Notice the open end of the master link retaining plate is facing down.
Еще один человек закончил это руководство.
