Введение
How to access the camera within the device for a replacement.
Выберете то, что вам нужно
Insert a plastic opening tool into the space between the screen and the back side.
Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
Lift the detached screen from the camera side until you can see the inside of the tablet.
There is a black tab behind the long ribbon cable. Lift up the black tab.
For the ribbon cable in the back, pull the black tabs on the side out.
Detach the ribbon cables connecting the screen to the motherboard.
Remove any tape that is holding down the ribbon cables. Set it aside.
Pull out the two black ends of the base on the motherboard.
Slide out the camera’s ribbon cable once the ends are loosened.
Еще один человек закончил это руководство.
