Coby Kyros MID7024 Speakers Replacement
Выберете то, что вам нужно
  1. Coby Kyros MID7024 Speakers Replacement, Back Cover: шаг 1, изображение 1 из 2 Coby Kyros MID7024 Speakers Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Begin by ensuring that the device is powered off.
    • To replace the back cover of the device you must pry it open using the access points. One is located on the top of the device above the camera and the other is on the bottom left hand side.
    • Use the spudger to pry at the access points to open the device.
  2. Coby Kyros MID7024 Speakers Replacement: шаг 2, изображение 1 из 3 Coby Kyros MID7024 Speakers Replacement: шаг 2, изображение 2 из 3 Coby Kyros MID7024 Speakers Replacement: шаг 2, изображение 3 из 3
    • Once the back cover begins to separate from the body of the device continue working the spudger around the perimeter of the device until the back cover is free.
    • You will hear some popping and cracking noises as you pry open the device. These sounds are the internal clips coming apart.
    • Once the back cover is free from the body of the device, open both sides like a book, placing them flat on the table as shown. Be sure to pay attention to the speaker wires that hold the two pieces together.
  3. Coby Kyros MID7024 Speakers Replacement: шаг 3, изображение 1 из 3 Coby Kyros MID7024 Speakers Replacement: шаг 3, изображение 2 из 3 Coby Kyros MID7024 Speakers Replacement: шаг 3, изображение 3 из 3
    • This step is only necessary if you intend to repair or replace the back cover and/or speakers of the device.
    • In order to replace the back cover you must remove the speakers. Place the Spudger under the plastic frame of the speaker as shown. Pry up, popping the corners of the speakers out of of their bracket and lift the speaker out.
    • Be sure not to pull on the speaker's wires or body too hard as you may damage them.
  4. Coby Kyros MID7024 Speakers Replacement, Speakers: шаг 4, изображение 1 из 1
    • With the speakers now free from the back cover trace their wires back to the area where they connect to the motherboard.
  5. Coby Kyros MID7024 Speakers Replacement: шаг 5, изображение 1 из 2 Coby Kyros MID7024 Speakers Replacement: шаг 5, изображение 2 из 2
    • Use a soldering gun to remove the positive and negative wires connecting the battery to the motherboard.
    • Follow the guide on soldering to assist you in removing the battery.
  6. Coby Kyros MID7024 Speakers Replacement: шаг 6, изображение 1 из 2 Coby Kyros MID7024 Speakers Replacement: шаг 6, изображение 2 из 2
    • To completely remove the speakers from the device use a soldering iron to unsolder the connection points located at the end of each wire.
    • Follow this guide on soldering to help you with unsoldering the wire from the motherboard.
Заключение
Jacob Bartell
Участник с: 03/21/16
351 Репутация
Автор 2 руководств
Команда
Clemson, Team 6-3, Benson Spring 2016 Участник Clemson, Team 6-3, Benson Spring 2016
CLEM-BENSON-S16S6G3
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 183
