Coby Kyros MID9742 Digitizer Replacement
Выберете то, что вам нужно
  1. Coby Kyros MID9742 Digitizer  Replacement, Outer Casing: шаг 1, изображение 1 из 1
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Coby Kyros MID9742 Digitizer  Replacement: шаг 2, изображение 1 из 1
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Coby Kyros MID9742 Digitizer  Replacement: шаг 3, изображение 1 из 1
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  4. Coby Kyros MID9742 Digitizer  Replacement, Screen: шаг 4, изображение 1 из 1
    • Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
  5. Coby Kyros MID9742 Digitizer  Replacement: шаг 5, изображение 1 из 1
    • Before removing the screen from the cover, dissconnect the large gold ribbon cable by gently sliding the black tab out until it clicks.
    • Gently pull the ribbon cable from the port.
  6. Coby Kyros MID9742 Digitizer  Replacement: шаг 6, изображение 1 из 1
    • Remove the screen from the device.
  7. Coby Kyros MID9742 Digitizer  Replacement, Digitizer: шаг 7, изображение 1 из 1
    • Gently pull on the black tab connecting the ribbon cable to the back of the tablet.
    • Remove ribbon cable from port to free the digitizer.
Заключение
Еще один человек закончил это руководство.
Ian Swett
Участник с: 03/11/15
597 Репутация
Автор 5 руководств
Команда
Colorado Springs, Team 5-3, Panko Spring 2015 Участник Colorado Springs, Team 5-3, Panko Spring 2015
UCCS-PANKO-S15S5G3
3 членов
Автор 12 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 645
