Введение
For sticky cold/hold buttons, you may only need to clean the button. This guide will show you how to fully remove and replace the button.
Note: This guide requires soldering skills. If you don't know how to solder or want to brush up on your skills check out this handy tutorial.
Выберете то, что вам нужно
Starting from where the cord attaches to the handle, pull apart the two plastic panels.
Continue separating the back panel, working along the seam.
With moderate force, completely remove the back panel from the hair dryer.
Hold the hair dryer by the nozzle so that the handle points to the left.
Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
Lift the attached electrical wiring and heat shield completely out of the hair dryer.
Hold the electrical switches so that the wires are facing upwards.
Focus on the middle of the three buttons.
Desolder the button at the circled locations.
2 участников успешно повторили данное руководство.
2 Комментариев
That's not a capacitor, that's an ion generator like this one https://www.goldmine-elec-products.com/p...
