Convert a 360 (Fat) hard drive into a 360 S hard drive
Выберете то, что вам нужно
  1. Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: шаг 1, изображение 1 из 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: шаг 1, изображение 2 из 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: шаг 1, изображение 3 из 3
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disassembly tip: шаг 2, изображение 1 из 1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: шаг 3, изображение 1 из 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: шаг 3, изображение 2 из 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: шаг 3, изображение 3 из 3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: шаг 4, изображение 1 из 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: шаг 4, изображение 2 из 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: шаг 4, изображение 3 из 3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
  5. Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: шаг 5, изображение 1 из 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: шаг 5, изображение 2 из 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: шаг 5, изображение 3 из 3
    • If you do not use an official hard drive, you will need a WD hard drive, the Xbox hard drive sector security file and HDDhackr to partition the drive. Partition 2 must be restored manually.
    • After removing the drive from the old enclosure, open the new enclosure.
    • Put the drive in the enclosure label side up. Space may need to be added for 7mm drives.
    • Close the enclosure and install it in your console.
Финишная черта
2 участников успешно повторили данное руководство.
Nick
Участник с: 11/10/09
88 923 Репутация
Автор 49 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 542 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 54
За всё время: 3,496
